jyang is distributed as a java jar file called jyang .
The synoptic is :
jyang [-hw] [-f format] [-o outputfile] [-p paths] file [file]*
jyang (java Yang) is a parser for the YANG data model. jyang is an open source project with a GPL licence.
jyang is a work of the Madynes Inria project.
-h : print the synoptic
-w : print warning
-f format : format for a translated output (yin format supported, other will be added)
-o output file : name of the translated output (standard output if not given) ignored if
                             no format are given
-p paths : paths where to find other YANG specifications (local directory by default). An
environment variable YANG_PATH may be setted.
file [file]* : file(s) containing YANG module(s). It must be one module or sub-module
             for each file.
